Re: f 20 need help
Posted by Old-F20 on August 07, 2012 at 17:20:38 from (71.7.101.5):
In Reply to: f 20 need help posted by badger bob on August 07, 2012 at 17:01:34:
find a piece of steel or copper tubing that will just fit in the lifter holes, then duct tape one end if it to your shop vac hose. sounds pretty hillbilly'ish, but it works!
