Re: Polarization of cub
Posted by Janicholson on August 07, 2012 at 18:49:18 from (96.24.99.126):
In Reply to: Polarization of cub posted by FrankxR on August 07, 2012 at 18:40:00:
Under the Regulator there must be a ARM (or GEN) terminal hiding. It just must be there.
The L terminal is hooked to the fuse for the lights, and also supplies ignition voltage if it is a coil and points ignition, if a mag, no voltage goes to it ever.
The Bat terminal hooks to the Amp gauge, on the terminal not connected to the big terminal on the starter switch. That Load terminal should not have a supply going to the lights with this regulator, Now supplied by the L terminal wire.
All wires mentioned should be 10 gauge. The F terminal should never be touched with the Bat voltage, it will burn out the regulator. Jim
