Re: M Farmall power steering set up
Posted by iowa steve on August 07, 2012 at 19:47:46 from (207.199.217.237):
In Reply to: M Farmall power steering set up posted by Raltn on August 07, 2012 at 16:58:06:
The one on mine uses the bolts on the outside of the governor cover to bolt on the bracket and the fan shroud was cut a little for clearance as the pump is outside just a bit,the bracket may bolt on the front of the block too i cant remember for sure.
