Posted by Owen Aaland on August 07, 2012 at 19:50:22 from (216.47.35.56):
In Reply to: Super C spark plugs posted by Brett Helmkamp on August 07, 2012 at 17:57:33:
Increasing the spark gap on the plug is not going to do much to stop the fouling. You need to either remove the source of the deposits, could be fuel or oil, or change to a hotter heat range plug.
I believe a lot of the problems with Champion plugs comes from the changes in fuels, oils, and the way the tractor is used. With the end of leaded fuels, in order to combat fouling, Champion changed the recommendation for standard duty plugs from D15Y to D18Y. There are still some parts books out there still recommending D16 plug which was replaced by the D15Y about 50 years ago. If you are only using your tractor for light duty you probably need to use a D21 instead of the D18Y. If you cross the Autolite 3116 back to Champion it usually comes back as a replacement for the D18Y and/or D21.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
