Re: f 20 need help
Posted by F-Dean on August 08, 2012 at 06:34:26 from (166.249.128.79):
In Reply to: f 20 need help posted by badger bob on August 07, 2012 at 14:15:45:
On my 10-20 (similar design), I made a cleaning rod using an old push rod. My problem was that the dirt and crud was so caked on the lifters and hard that I could not adjust the rocker arms.
I cut the end off and ground away a portion of the rod to make a "drill point" and put it in a drill. Don't press too hard and check often for the metal-on-metal sound to make sure you are thru the Crud.
