Re: Impact gun Question?
Posted by JRSutton on August 08, 2012 at 07:04:50 from (75.130.109.233):
In Reply to: Impact gun Question? posted by FC Andy on August 07, 2012 at 12:51:05:
Air line should probably be 1/2".
But distance makes a big difference too.
Think of that line as a long narrow balloon. The longer it is, the more you loose to expansion of the line - and friction flowing through it.
It's usually best to use steel pipe 3/4" or so - up to the point where you can run a short section of hose to your work area.
Obviously if your compressor is running full time while you use a tool - it's not really going to work at peak efficiency either.
