Posted by The tractor vet on August 08, 2012 at 08:55:34 from (76.212.234.198):
In Reply to: 3688 TA pressure posted by dwag on August 07, 2012 at 16:17:11:
When you replaced the spring did you check spring lenght ?? Did you replace the MCV pump ?? are you sure that you do not have a leak and loosen pressure else were . Normally i have to remove a coil or two to decrease pressure to get what i want . Normally with a new spring kit you would be at around 290-310 and depending on what tractor it is i set pressures between 235-275.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
