Re: Farmall 450 Hyd pump and system
Posted by Janicholson on August 08, 2012 at 13:35:34 from (199.17.55.151):
In Reply to: Farmall 450 Hyd pump and system posted by Roger Schnell on August 08, 2012 at 06:23:56:
You likely have a Oring or pinhole air leak in the suction line to the pump. Putting pressure in the reservoir (30 PSI max) and using some dishsoap in a utility bottle sprayer, at one teaspoon per 12 OZ, will show up a leak, if it does not show up from oil. Some bad Orings leak into the line, but not out. Cracked end fittings are also possible. Jim
