Re: Swapping my M's 6 volt cut out for a 6 volt VR---help
Posted by John T on August 08, 2012 at 13:59:35 from (216.249.82.117):
In Reply to: Re: Swapping my M's 6 volt cut out for a 6 volt VR---help posted by Patrick HMD on August 08, 2012 at 12:35:07:
The only other issue is the VR on that diagram is a 4 terminal (BAT FLD LOAD ARM) instead of a 3 terminal (BAT FLD ARM). If yours is a 4 terminal like shown, loads are fed off the VR's LOAD terminal instead of from the ammeter as on 3 terminal VR's that dont have that extra 4th Load terminal. No theres no ignition ballast resistor on a 6 volt tractor that uses a 6 volt coil. Yes you polarize from BAT on the VR over to ARM or GEN or else from BAT direct down to the gennys ARM post
John T
