The light, (or diode with band toward alternator, or 10 ohm resistor) connects to the ignition voltage at the coil where it attaches to the ignition switch wire. The diode, light, or resistor is needed to supply excitation voltage to the alt. The resistor, diode, or light prevent the alternator from keeping the engine running when the ignition is shut off. the coil should be hooked up so that the negative terminal goes to the distributor. (assumes it has a coil ignition, not a Mag.) with a mag, other steps are needed. Jim
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
