Re: More time on that #*@%# M.
Posted by mkirsch on August 09, 2012 at 05:59:52 from (64.80.110.74):
In Reply to: More time on that #*@%# M. posted by oldtanker on August 07, 2012 at 20:53:45:
There used to be a relocation plate available for the factory wide fronts on these old tractors. It would move the front end back underneath the tractor and reduce the turning radius tremendously.
All it is is a piece if heavy plate. I bet you could make one up yourself pretty easy with a cutting torch.
