Re: Looking for 1026 hydro input shaft
Posted by RPM1941 on August 09, 2012 at 07:07:05 from (173.23.76.185):
In Reply to: Looking for 1026 hydro input shaft posted by curtisk84 on August 08, 2012 at 14:23:09:
If you cant find a good used shaft, get the later part new or used (spline count different) & also drive disc off later Hydro such as 1066/186/3488. This is why IH/CNH dont furnish old spline count shaft.
