Re: Seat problem with M
Posted by Centex Farmall on August 09, 2012 at 09:37:50 from (166.147.72.30):
In Reply to: Seat problem with M posted by oldtanker on August 08, 2012 at 21:28:42:
Rick,
The condition of your seat sounds like a plain M that I have. I'm only 150 soaking wet and the seat squats way down when I'm on it, also bushings worn. So I can imagine yours being plenty uncomfortable. You bounce left and right and up and down while going.
I rebuilt on a SM I have with new bushings and new springs. I got the spring from either this site or OEM, can't remember which. The spring is actually too heavy for me but would probably be perfect for a heavier person. Made a huge difference in the ride!
The seat bracket you have should have several holes on the bottom to allow adjusting fore and aft. Should be all the way back for a taller person. I like mine set far enough back to allow me to stand without the back of my legs hitting the seat. If you're not on too rough or uneven ground you can stand while you're raking or plowing and makes steering a little easier, IMO.
