From the time you turn the gas off to the time the tractor runs out of gas will be at least 60 seconds. You could get on the seat twice before it dies. :lol: That is how I turn mine off.
You can forget to turn the diesel on and run the tractor for over 25 minutes before it runs out of fuel. Trust me on that one. :oops:
The adjustments are a PITA, but they are necessary. My carb lever thing (the one behind the carb) was welded on and a little rigged up. It took me a good 30 min to get the weld ground off and retapped/hole died (is that a word?) and back on. Adjusting the starting valve clearance was the biggest pain IMO.
I think the starting valves work both ways. Not sure if I said it, but mine will suck the carb dry while I am running on diesel. It DOES NOT run away like yours. Mine will just keep sucking if you leave the gas on. I have not had the covers off the intake manifold. Mine is a little hard starting and that may fix the issue. Mine takes 3/4 choke even in summer.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
