When on diesel the butterflies in the manifold are wide open, and they close on gas cycle to make air travel through the carburetor part of the intake manifold. Does it smoke quite a lot of blue smoke when running on gas. You might not have total diesel fuel shut off when running on the gas cycle and the unburned diesel fuel makes it rev up when throwing decompression lever. Two ways to test. Open the bleeders on nozzles when running on gas to see if it changes exhaust, if pump is adjusted properly it will not. Other thing is to shut it down on diesel and immediately check for gas in bowl of carburetor. You may not be able to get gas out of carb drain with engine running on diesel due to pressure differential. Also, if it is using the gas out of carb it will die when trying to switch back to gas when running on diesel.
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo
... [Read Article]
Latest Ad:
[More Ads]
