Re: 113 cid engine
Posted by gene bender on August 09, 2012 at 18:17:51 from (67.55.226.123):
In Reply to: Re: 113 cid engine posted by Roy Kennedy on August 07, 2012 at 13:48:06:
Where is the block cracked if its not between the sleeves and just cracked behing the carb that crack can be repaired easy with rubber cement or JB weld or even fiberglass so wait untill you get the head removed before jumping out to get another block.
