Posted by CNKS on August 09, 2012 at 18:31:23 from (216.144.104.128):
In Reply to: farmall carb posted by Aaron andersen on August 09, 2012 at 17:55:56:
Out is more fuel. However the carb is adjusted when at operating temp at wide open throttle. Turn the main jet screw in until the engine stumbles, then out until smooth plus maybe 1/4 turn 1/2 turn more. Adjust the idle mixture by turning the idle mixture screw in or out until smooth. Engine should accelerate from idle to WOT without stumbling. You may have to repeat the adjustment of both idle and WOT adjustments a couple of times. If you can't get that to work the carb probably needs cleaning. You also need good fuel flow out of the tank in order to adjust the carb correctly.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
