Re: 6 volt generator
Posted by gbs on August 09, 2012 at 18:50:34 from (71.51.250.29):
In Reply to: 6 volt generator posted by James Williams on August 09, 2012 at 13:34:06:
it can be done buy installing a 12 volt regulator,but check with a repair shop some 6 volt gen. have a third brush that is used with a cut-out relay system that needs to be unhooked ,the 6 volt generator can produce up to 17 volts ,i have an h set up that way and know of a couple more,use to work with a man that would put a 12 volt reg. on 24 volt military gen. and convert the rest of the old truck to 12 volt because 24 volt components were expensive compared to 12 volt
