Re: Farmall A goes down on coolant
Posted by Janicholson on August 09, 2012 at 18:58:43 from (96.24.99.126):
In Reply to: Farmall A goes down on coolant posted by johndeeregreen on August 09, 2012 at 18:40:21:
If you fill the radiator,to the neck it will push some out as it warms up. This goes into the overflow pipe, and may not show much. They are supposed to be about two finger widths below the neck. If it is at that level, and goes down from there, it can be going into the combustion chamber. If the tractor makes light grey to white smoke, that is possibly the case. If it starts on 3 cyinders, then, after a bit runs on 4, it is pretty certain to be a leak into the combustion chamber. Causes are a bad head gasket, or cracked head. Gasket most likely. If you let it sit for 2 days, then remove the plugs and crank the engine (ign off) coolant will spray out of the leaking cylinder. Jim
