Re: firing order for farmallsupera
Posted by mkirsch on August 10, 2012 at 05:31:54 from (64.80.110.74):
In Reply to: firing order for farmallsupera posted by redpocadot on August 09, 2012 at 17:46:25:
You can SEE when the piston comes up on TDC in a C113 engine, just by shining a light down the #1 spark plug hole.
Use the thumb method to find the compression stroke, then simply watch the piston come up to TDC.
