Re: 300 Row crop with no hydraulics
Posted by mkirsch on August 10, 2012 at 05:44:37 from (64.80.110.74):
In Reply to: 300 Row crop with no hydraulics posted by VA Gasman on August 10, 2012 at 05:36:36:
The hydraulics are not under the sediment bowl on a 300 row crop.
The valves are up under the hood, in front of the instrument cluster.
The reservoir is the base of the steering pedestal.
Look carefully for hydraulic lines running from the pump back along the engine, up the rear of the engine, and disappearing under the hood.
If there are no hydraulic lines, the pump is probably burned up from running dry. That's $800+ right there.
If the rest of the parts are also missing, your only choice is to go to a salvage yard and cannibalize them off another 300. Then you're at the mercy of the yard owner on price.
