Re: Farmall A goes down on coolant
Posted by Russ from MN on August 10, 2012 at 06:44:28 from (68.235.89.1):
In Reply to: Farmall A goes down on coolant posted by johndeeregreen on August 09, 2012 at 18:40:21:
As long as the cores are covered when it's cold that is enough. If it truly is leaking I would try some stop-leak.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
