Re: Rebuilding Brakes on a Farmall C
Posted by gene bender on August 10, 2012 at 10:53:40 from (67.55.226.123):
In Reply to: Rebuilding Brakes on a Farmall C posted by cmowinman on August 10, 2012 at 08:44:00:
Those are band brakes just take the cover off and they will be easy to replace. You will need to free up the linkage and the bottom screw is adjusted to keep some slack in the band so it seats better. Make sure someone hasnt up-graded to disc brakes. Disc brakes are a different type and installing is different. Just remove the cover and its easy to see which type you have.
