Re: H Clutch stuck
Posted by Janicholson on August 10, 2012 at 12:09:23 from (96.24.99.126):
In Reply to: Re: H Clutch stuck posted by Tuckermac on August 10, 2012 at 11:27:06:
Rust can do it if sitting for 6 months or so (shorter if high humidity).
Oil can contaminate the clutch and with heat, become an adheasive goo. Mice and other rodents can deposit "used oats" in the chamber.
New clutch disks can operate on the edge of wear on the clutch shaaft causing the disk to press against the pressure plate, or flywheel.
Using a wooden block to hold the pedal down when the tractor sits for some time will also prevent the reocuurance. Jim
