Re: balast in tires
Posted by mkirsch on August 10, 2012 at 13:31:11 from (64.80.110.74):
In Reply to: balast in tires posted by longear on August 10, 2012 at 11:04:58:
Depending on the size tire, it might be a wash to add iron weight.
For example, a Cub only holds about 90lbs of calcium chloride solution in each tire. A set of iron weights would add 150lbs per tire.
On an H size tractor, two sets of factory wheel weights is about as effective as filling the tires.
The problem with windshield washer fluid is it's mostly alcohol. Calcium makes the fluid HEAVIER. Alcohol makes the fluid LIGHTER.
Beet juice you have to order, have shipped... Probably cost more than iron weights.
