Re: Farmall Super H 12v conversion
Posted by Dragonclaw on August 10, 2012 at 16:32:50 from (69.11.163.106):
In Reply to: Farmall Super H 12v conversion posted by Dragonclaw on August 08, 2012 at 15:23:22:
Everything seems to be working great thank you all for all the help.
I'm fairly certain if i run into any other problems it will either be that the coil is messed up (was not replaced, and has run hot before) or the resistor i used was not rated for the right amperage and has burned up.
O and just for future info in case some one does a search for this info and finds this post the belt we used was 31 inches.
