Re: frozen engine on farmall 300
Posted by rustred on August 10, 2012 at 16:54:00 from (184.151.222.236):
In Reply to: frozen engine on farmall 300 posted by harold s on August 10, 2012 at 16:04:27:
put it in a warm building to thaw out, just joking. your not giving much info. was exhaust covered or left open to rain, if so it is a major teardown and go from there. you can remove plugs and look in with a flashlite if you see rust, its still a tear down. only time soaking the cyl's with lube works is when exhuast is coverd and it gets stuck from condensation sticking the rings to the walls.i have experienced this not even working either.
