Posted by Janicholson on August 10, 2012 at 18:23:27 from (96.24.99.126):
In Reply to: Wiring a Cub posted by patsdeere on August 09, 2012 at 22:57:26:
The diagram you have drawn is of a 4 position switch. The wire shown as taped off, is coming from the switches First two positions (knob positions) L and H. it is probably not a very heavy wire. it was not, originally hooked up to the L terminal, it went to the F terminal of the generaator It is correctly disconnected,because the L H positions are not used at all with a real voltage regulator (as yours is). The L terminal on the regulator can be connected (with 10 gauge wire) to the fuse on the light switch instead of the wire now probably going to the amp meter. This will allow the gen to regulate the battery charging rate to be a little better controlled. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
