harold, This method will work every time , best done with engine out of the tractor on an Engine stand, but inframe is OK too. usually in 1 afternoon....... 1, Remove all sheet tin, Gas tank, wiring Harness, Valve cover, Head, and Oil pan, Also all rod caps too. 2. check area around tractor and move away any flammable items and liquids. 3. roll tractor outside in the open, 4. Fill the cylinder with the most "volume" with Dsl add just a splash of Gas, set it on fire. 5. Drink a cup of coffee, Coke or Adult beverage while and until the fire burns itself out! 6. When the fire is out take a hammer and oak block and drive the piston out from the bottom going to the top. 7.repeat on the cylinder with the 2nd most volume and so on till all the pistons have come loose. """The fire, expands the cylinder and allows the rust to break loose.""" As the volume decreases you may have to do 2-3-4 or more burnings to generate enough heat to pop the rust. Just pay attentions to your surroundings and be very careful. 8. Repeat steps 4-5-6 on each cylinder and you will have an engine freed ed up and loose again. You might be able to salvage the cylinder or pistons if they aren't too rusted up. Hope this helps! Later, John A.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
