Re: air breather cleaning
Posted by Denny ('60 Lo-Boy) on August 11, 2012 at 06:27:46 from (76.1.32.207):
In Reply to: air breather cleaning posted by The Red on August 10, 2012 at 17:02:40:
It wouldn't get sucked in any more than engine oil. Run it a moderate length and change back to oil.
When you change the oil in the cup, clean out the crud. If you don't overextend your maintenance it won't build up.
If you're concerned about paint damage use soap and water and dry thoroughly.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
