Posted by Craig45 on August 11, 2012 at 08:33:59 from (71.191.1.123):
Engine runs erratic and rockshaft to carb throttle plate vibrate back and fourth. This is worse as speed is increased. If I hold the shaft still with my hand the engine smooths right out. I adjusted the shaft as per paragraph 66 in the service manual but this had no effect. I removed the housing cover and there is a lot of play between the thrust bearing and governor sleeve, flyweights are real loose. Has anybody delt with this situation before? Any help would be greatly appreciated. Thanks
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
