Posted by rustred on August 11, 2012 at 20:13:13 from (184.151.222.174):
In Reply to: Good Carb Rebuilder posted by Mark W. on August 11, 2012 at 19:54:22:
well in 2 yrs. time anything can happen, sure sounds like you have a fuel restriction problem going to the carb. you may even have a bit of water in the carb bowl, or a piece of rust floating around to block the jet. have you drained the bowl? have you checked for good gas flow at line before entering carb? you dont need to rebuild the carb to make it run, you need it clean , float set and adjusted properly. i have cleaned so many carbs by just soaking them in cleaner and reassembling with the old parts and even making my own gaskts.in doing this i can spot what needs to be replaced, such as needle and seat or float and so on.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
