If your alternator is the original, it has an external Voltage regulator. It is possible with age, that it is showing some current through the light when running. It happens. There should be voltage on both leads to the light, resulting in no light when running. when stopped with the key on, the light gets grounded in the regulator, and has current will flow from the key through the light, to the VR. If the charging voltage is close to 14.2, I would leave it as is. If it is less than 13.8 I would probably have the alt and VR checked. Most likely the VR. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
