Re: Super A: Flow rate of hydraulic pump?
Posted by IH fan on August 12, 2012 at 07:20:25 from (108.236.95.172):
In Reply to: Super A: Flow rate of hydraulic pump? posted by CNKS on August 12, 2012 at 05:54:06:
I'm not sure the flow rate of a SA pump, but ifiit's like the C, SC, etc., it's probably in the 4 to 5gpm range at full throttle. Since a pump/motor hydraulic system is only about 75-80% efficient, that means you really only have about 3-4 gpm and a 3-4 gpm motor at 1500psi probably won't drive more than a 21" walking mower, no it won't work (pressure X flow divided by 1714 or 1500 X 4 / 1714 = 3.5hp.)
