Re: Super A: Flow rate of hydraulic pump?
Posted by Janicholson on August 12, 2012 at 07:50:49 from (96.24.99.126):
In Reply to: Super A: Flow rate of hydraulic pump? posted by Bruce Brittain on August 12, 2012 at 05:54:06:
A belt Pulley, or PTO driven pump will work. Match the pump to the motor and all is well.
A simpler solution might be to put an engine on the mower. This allows the tractor to be throttled down and stopped while the mower still runs. A switch to shut it off from the operators station on the tractor is a good idea. Engines can be found for less than even one of the hydraulic pump/or motors. Jim
