Re: ih 656 amp light help
Posted by Owen Aaland on August 12, 2012 at 13:03:50 from (216.47.35.23):
In Reply to: ih 656 amp light help posted by mh mo. on August 12, 2012 at 06:41:06:
This is the wiring diagram for your warning light.
http://www.tractorshed.com/gallery/community/c3719_lrg.jpg
If your wiring is good you may have an alternator that is not working properly or a bad relay in the regulator. If the alternator is working properly you should have over 6 volts on the R terminal at the alternator. That voltage from the alternator closes the relay in the regulator and turns off the indicator light. When the relay closes it also provides battery voltage to the field windings in the alternator.
If the relay does not work the power to the alternator field coils is provided through the indicator lamp and the resistor at the regulator. Since that circuit provides less than battery voltage it can keep the alternator from reaching its full output.
