Re: how to tension water pump belt 300u
Posted by Tim Yates on August 12, 2012 at 18:33:48 from (71.171.18.245):
In Reply to: how to tension water pump belt 300u posted by realolman on August 12, 2012 at 17:53:54:
Loosen the jam nut on the pulley and then back out the slotted
set screw be sure to use some penetrating oil on all the
threaded parts. Then use a block and hammer to lightly tap the
front half of the pulley in a clockwise direction to tighten the
belt. Rotate the engine every so often to keep the belt tracking
properly in the adjustable pulley.
