Re: More 560 hydraulic questions
Posted by pete 23 on August 12, 2012 at 18:57:18 from (74.32.238.2):
In Reply to: More 560 hydraulic questions posted by Buzzard2005 on August 12, 2012 at 18:39:38:
On your outlets to the rear from that right side valve, center lever, do they have a block they go to under the valve. If so, I would bet the o-ring in that check valve is bad and allows oil to just flow back to return. You can just take the plug out of the end of that check valve to replace o-ring on piston, that is if it does have a check valve. It was an option.
