Re: More 560 hydraulic questions
Posted by Armand Tatro on August 12, 2012 at 19:11:20 from (98.227.26.140):
In Reply to: More 560 hydraulic questions posted by Buzzard2005 on August 12, 2012 at 18:39:38:
The way both of my 560's are plumbed (1 gas; 1 Diesel: both have fast hitches) the right-hand lever(left valve) operates the fast hitches; the left hand lever operates left side remote and center lever lever operates right side remote which has been extended to the rear because the rear remote operates the fasthitch. Now having said that I need to look at the Diesel because it came with no fast hitch. The fasthitch was an option. The gas 560 had the fast hitch from the factory so the plumbing could be a bit different. On the Diesel I hooked a pair of hoses into the right front remote to add a second rear remote. Our Farmal 400 was plumbed the same way because Dad and I added an after-market 3PT. hitch to it in the mid 60's. By the way 3 remotes are not enough when you add a hyd.loader with a grappel attatchment so I am going to add a 3 spool valve to the Diesel and a 4 spool valve to the gasser. I have already converted a '41 Farmall M and a M&M M5 to 6-valve hyd. Hope this helps. Armand
