Re: 706 gas fuel bowl
Posted by caterpillar guy on August 13, 2012 at 02:09:30 from (66.227.141.21):
In Reply to: 706 gas fuel bowl posted by David Truesdale on August 12, 2012 at 21:46:58:
That is the way it should be .That is a sign that you have a good seal on the sediment bowl. Just let it loose to bleed the air out then tighten back up. NO on the inline filter restricts the flow to much.
