Re: F-12 Questions
Posted by Fawteen on August 13, 2012 at 02:49:57 from (72.65.125.148):
In Reply to: F-12 Questions posted by Fritz Maurer on August 12, 2012 at 21:04:29:
Two wheels steer easier than a single wheel, due (I think) to the caster angle.
The tee shaped arm was for linkage on steerable front mounted cultivators. The cultivator gangs shifted to follow the front wheels.
Not getting a mental picture of the wheel spokes you're talking about, maybe for attaching wheel weights?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
