Re: how to tension water pump belt 300u
Posted by realolman on August 13, 2012 at 02:55:13 from (108.22.71.120):
In Reply to: how to tension water pump belt 300u posted by Janicholson on August 12, 2012 at 18:41:59:
Janicholson said: (quoted from post at 18:41:59 08/12/12) When it is tight, it can be pushed in a total of 1.125 inches, or 3/4" from straight edge between pulleys. This is to keep the fan/wp bearings from wear. The belt is so oversized that loose is OK Jim
Thanks for your help. That is good to know. this is so loose I can turn fan pretty easily. I'll hafta check how far I can push it in. I never saw any evidence of overheating. maybe it doesn't need tightened.
this tractor was changed from 6 - 12 v before I bought it, and the lights were never hooked back up and the gauges don't work, so I thought I would see if I could get the gauges to work.
Things kinda went in the toilet fast.
I was surprised to see the alternator belt broken and that's when I saw the belt so loose on the water pump. I think the alternator has something wrong ... it doesn't feel good ... as if something was loose and dragging inside. I pulled the wire going to the switch off the alternator, not realizing that there was a choice of four pins to put it back on... I'm wondering what I'm gonna hafta do to get a new alternator belt on
... and the gauges still don't work :)
This post was edited by realolman at 03:17:47 08/13/12 5 times.
