Re: 656 PTO not engaging
Posted by the tractor vet on October 08, 2000 at 10:11:12 from (216.196.14.43):
In Reply to: 656 PTO not engaging posted by David on October 08, 2000 at 07:32:22:
I am not real sure ,but if the valve on a 656 is the same or similar to the o6-66 there is a tiny pin that hold the two half's of the valve together . Just went out to the truck and got the book out and looked to make sure ,The valve is similar you broke the littel pin .Unhook the linkage on top of the valve ,then take the hex headed plug out of the bottom left side of the pto and remove the valve instead of one pice you will have two , replace the littel pin and reinstall you will be back in business.
Post A Followup
: Re: Re: 656 PTO not engaging
