Re: 1945 farmall M differential
Posted by D Slater on August 13, 2012 at 13:17:06 from (184.15.20.202):
In Reply to: 1945 farmall M differential posted by Ben Kienert on August 12, 2012 at 21:35:13:
You never know with pullers. If reverse is also slower than a standard M you probably have the slower first speed gear. Or the pullers may have a W-6 ring and pinion put in. Or there streaching the RPMs.
Was wanting to say or other pullers would be faster than you if they installed W-6 ring and pinion and you run standard gears..
This post was edited by D Slater at 17:18:23 08/13/12.
