Re: Brass float in Farmall Regular
Posted by Nebraska Cowman on August 13, 2012 at 16:37:01 from (66.252.125.47):
In Reply to: Re: Brass float in Farmall Regular posted by wtk on August 13, 2012 at 14:54:57:
yes, that center stem is steel and they rust out. Have you had it apart? I have new stems.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
