Your rims are mounted in the narrowest setting. They can also be installed facing the same direction on the outside of the hub or they can be reversed and mounted either inside or outside on the hub. That gives you four wheel spacings.
To remove the rim take out the three bolts and then move the rim until you can tip one of the lugs over the wheel. From that point a little wiggling should allow the rim to come off the hub.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
