Re: Governor on H Farmall
Posted by D Slater on August 13, 2012 at 18:59:12 from (184.15.20.202):
In Reply to: Governor on H Farmall posted by Kenneth Blackwelder on August 13, 2012 at 18:06:58:
From the front cam bearing bore over to a opening in the front engine cover plate, over to a opening near the front top of the governor. Same passage oils the idler gear bearing. If you remove the governor housing from the engine you can see the outlet. Least thats how I remember the path of the oil.
