Hi Steven, the PTO clutch could be stuck. Re transmission clutch slipping, the pressure plate fingers are adjustable thru the clutch inspection plate on bottom of clutch howsing. The dual stage clutch is more difficult to assemble and adjust than single clutch, see following from Bernard le mecano: Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to align the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then pressure plate, belleville spring and cover. Align all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
