Re: My M front rims mounted inside of hubs. WT*!!!
Posted by Bob M on August 13, 2012 at 19:51:49 from (67.240.168.11):
In Reply to: My posted by Patrick HMD on August 13, 2012 at 17:02:05:
As the others point out the rim/tire can be removed without removing the wheel. But it takes a bit of fiddling to accomplish.
Tip: If the front tires are wider than stock (like 6.50 x 16) it helps to jack the entire front end (jack from beneath the clutch housing) then remove the 3 mounting bolts from BOTH rims. By moving the now loose rims around you will have more space in which to manipulate the rim/tire and work the rim lugs around from behind the cast wheel center.
