Re: SA Brake Job
Posted by Fixmnflym on August 13, 2012 at 22:03:28 from (184.19.66.161):
In Reply to: SA Brake Job posted by Doug Kieta on August 13, 2012 at 18:21:56:
third party image
third party image
Have mine apart right now. Not that hard. Jack it up and support it. Remove the wheel. Dis-connect the clevis where the brake band meets the brake pedal shaft. Support the final drive with a crane or a floor jack and remove the bolts between the final drive and the transmission. On the left side the bolts are right into the transmission. On the right, they hold the final drive to the extended housing. Move the final drive as an assembly straight out until the differential shaft clears. Brake band is right there. You will see when you get it apart. Good time to check seals.
